1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Ford "Chrome Clad" Aluminum wheels
Old 07-16-2015, 09:02 AM
jimd1050's Avatar
jimd1050
jimd1050 is offline
Worry later? IT IS LATER!
Hi Folks - My 2015 F-350 came with 18X8 "Chrome Clad" Aluminum wheels and I'm not liking the chrome. I can't really afford new wheels so I tried using charcoal PlastiDip (see my Signature pic - that's before they peeled). I followed their instructions to the letter, used their Cleaner and they peeled within a week. The center caps still have the PlastiDip on them but the wheels bubbled and peeled. The cladding is plastic, like a hub cap but does not seem removable. My next thought is to sandblast (I have my own sandblaster) the chrome off with low pressure so as not to eat up the plastic, then paint them with Krylon Fusion, a hard surface paint made for plastic.
Thoughts? (Besides "By the time you get through with the sandblasting and all the cans of PlastiDip and Krylon, you probably could have bought new wheels")
Thanks!
Old 07-16-2015, 09:49 AM
auburngrad's Avatar
auburngrad
auburngrad is offline
I think you will have to do something to get the plasti-dip to stick. Either sand blast or rough up withere some sort of sand paper.
Old 07-17-2015, 08:49 AM
6.2 V8 power's Avatar
6.2 V8 power
6.2 V8 power is offline
Its a lot of work but just have them powder coated. I wouldn't sand blast them and if you take the tires off the wheels and remove the TPS than you may as well do the coating.
Old 07-17-2015, 11:34 PM
jimd1050's Avatar
jimd1050
jimd1050 is offline
Powder coating would be ideal but you can't powder coat plastic... the "Chrome Clad" is basically a non-removable plastic hub cap attached to the aluminum base wheel.
I sand blasted the center caps and painted them gloss black today - they take enough away from the chrome that I actually like it. I may just leave it like that!! Thanks for the opinions guys...
Old 07-18-2015, 11:00 PM
ibheretoo's Avatar
ibheretoo
ibheretoo is offline
That does look good. Good job! If you still want the wheel all black, the same process that worked on the caps should work on the wheel. As far as I know, the caps are same being chrome over plastic.
Old 07-19-2015, 09:43 AM
6.2 V8 power
I thought you were talking about the wheel not the hub cap. They do look nicer now.
Old 07-19-2015, 11:04 AM
jimd1050's Avatar
jimd1050
jimd1050 is offline
It's not really an actual hub cap - look on the Ford web site in the Super Duty section. They're called "Chrome Clad Aluminum Wheels" - in reality, it's just an unfinished, cast aluminum wheel with a chrome plastic cover bonded to it somehow, but it can't be removed. I'm not sure what they were thinking but probably just another way to save on production costs! The more I look at the truck, the more I do like them now though. Thanks for the comments...
Old 07-23-2015, 12:46 PM
93-331-29PSI's Avatar
93-331-29PSI
93-331-29PSI is offline
The chrome cladding can be removed, but it'll take an old screwdriver and a mallet to convince the cladding. Do this only if you plan to strip the wheel and paint/powder.
Old 07-23-2015, 01:43 PM
Sous's Avatar
Sous
Sous is offline
Received 4,464 Likes on 2,853 Posts
I have had great luck with Plasti-dip. I did the wheels on my wife's VW beetle 2 years ago and they still look like the day I did them. It is her daily driver so I do have to clean them regularly and keep them looking good.
Her wheels had a clear coat on them, so perhaps the chrome reacted differently than the clear coat.
Jackson1991
04-23-2010 12:52 PM
07fordfx4
2004 - 2008 F150
03-29-2009 04:35 PM
white cat
1983 - 2012 Ranger & B-Series
12-12-2006 10:18 AM
jdew1920
2004 - 2008 F150
11-08-2005 10:51 AM
rebocardo
Paint & Bodywork
12-22-2002 12:06 AM
Quick Reply: Ford "Chrome Clad" Aluminum wheels
