Bronco II Ford Bronco II
Rear drive shaft substitute?
Old 07-13-2015, 09:40 PM
joshcha2's Avatar
joshcha2
joshcha2 is offline
I have 88 ford bronco ii xlt. My inner ball bearing and bearing cage in my rear drive shaft was destroyed after a mud off road session. And can't find anyone that has them! A guy has a 1985 bronco ii he's parting out. Wants to sell me his rear drive shaft.
My question is..
Can his U joint drive shaft work for my bronco that uses a CV joint drive shaft if they are the same length?
Old 07-14-2015, 11:27 AM
Josh S's Avatar
Josh S
Josh S is offline
Per the TRS tech articles '85 and '88 Bronco II's use the same transmission families (Mitsubishi FM series if manual, A4LD if automatic) with BW transfer cases so... in theory... the driveshafts should be interchangeable. Could you bring your old shaft when picking up the new one to do an actual comparison?
Otherwise Jeff's Bronco Graveyard offers the upgraded U-joint style shafts for $195. Someone there can tell you which one will work.
GKN Conversion Shafts-Broncograveyard.com
Old 07-14-2015, 08:25 PM
HappyJack's Avatar
HappyJack
HappyJack is offline
My question is..
The double cardan driveshaft needs a yoke output vs the flange on your 88. The early std. trans were shorter and the c-5 was shorter also. So as was said you need to check length. If you are considering going to a double cardan shaft the early stock shaft used 1210 series parts and has very little flex. If you have a suspension lift this may be a problem. By 88 they had the drive shafts all the same length.
If you do not have a lift most auto parts stores sell a replacement shaft. Or search car-part.com for 88 and up drive shafts.
Old 07-16-2015, 04:57 PM
Eddiec1564's Avatar
Eddiec1564
Eddiec1564 is offline
Here is some info on replacing the CV drive shaft with a regular drive shaft.
DIY Cheep Rear D shaft
mdr617
Bronco II
01-19-2011 08:31 AM
cadunkle
1978 - 1996 Big Bronco
11-29-2005 12:21 PM
casanovaceo
Offroad & 4x4
09-02-2004 09:03 PM
mmoore
Bronco II
09-27-2002 01:36 PM
Quick Reply: Rear drive shaft substitute?
