1991 F 150 cranks, but the key will not stay in run position and truck dies
I need some help from folks that might help me diagnose what is going on here. The truck will crank, but as soon as I take my hand off the ignition cylinder it kicks back and the truck dies.
Felt like this would be a fairly easy fix, just put in a new ignition cylinder and off to the races. However, with the new cylinder in place it is still doing the same thing.
I have looked at the actuator rod, and it does not appear to be loose or damaged.
Any thoughts on what could be causing this and what I could do to fix it?
kjhansen
23
06-13-2019 07:56 PM
themoparkid
07-21-2008 07:28 PM
