Do I need bigger alternator cable?
Check out this chart. I would suggest upsizing to a 6 gauge, personally. Stranded. Welding cable or marine grade cable make good choices. If you're in a winter salt region, you might want to consider tinned cable, but it's not really necessary.
Wire Gauge Amps Ratings for 12 volt Automotive Systems
-Kenneth
You're only going to overcharge if your voltage regulator doesn't work. If "lots of idling" is the only reason for upgrading, then a 220 amp unit is way over sized. I would go with something in the 160-185 amp range and save some money while still addressing the idle time issue.
I did the same thing on my truck about 5-6 years ago and went with a 165 amp unit, and have had no issues whatsoever. At that time, the 220 amp option was at least another $100, and just was not justifiable for me. All I did was run another charge cable to my driver side battery and left the original one alone... there was no need for the larger cable with the 165 amp unit. I also installed a monster fuse in the new driver side charge cable as an extra measure of protection.
zspeed130
12-09-2013 08:45 AM
strokin'_tatsch
08-26-2013 03:31 AM
BigSix1
10-27-2009 08:30 PM
