Evolution CTS 6.0 Speedometer Calibration Questions
Can anyone confirm if you can recalibrate the speedo and odometer for larger tires with this unit?
There is a spot to change the size but I think it only changes it in the edge unit and doesn't recalibrate the stuff in the dash?
My sizes are close so it's real hard to tell?
Worse case I will call in the a.m.
Thanks guys, Joe
Thanks guys, Joe
I'm running an Edge CTS Evolution on my '04 and it does not change the dash speedo. There is an option to display "corrected speed" on the Edge display that does display accurate speed - as compared to my GPS, but I haven't found a way to make it change the factory speedo readout to match my bigger tires.
ramrod7373
08-19-2012 06:25 PM
