Truck stalls after downshifting zf6
Lately when I am coming to a stop and roll up to a stoplight/sign in gear the rpms drop too much and it stalls. I let the clutch back out and it starts back, but will stall again if I coast in gear again.
If I just push in the clutch without the rpm's coming up like to change gears it doesn't stall, only when I downshift when stopping and then once I push in the clutch the rpms drop and don't recover.
Truck runs great otherwise, new motorcraft icp and cps doesn't help. Thinking maybe ipr, but idk. I can rev it in neutral and it doesn't stall only when it's under load coasting, it's like the injectors don't recover from being off while coasting in gear.
mine WAS doing the same thing. Would drop rpm, if thrown in N, coasting to stop. I finally got around to changing the fuel filters, at the bowl and prepump. Honestly, i have yet to see/hear the problem comeback. I'll repost later today, since i got some running around to do
yup...mines' the same way. There was one time where it dropped to about 300rpm, and it "caught" to stay alive....driving yesterday, i forgot to "listen/watch" for it. I think for me, it was a combo of both filters. Heading to beach today, so i'll pay attention, note if anything happens
After reading the thread, I'm more convinced it's HPOP related than Transmission.
I would monitor a few PIDs just to eliminate them as a possible cause:
ICP 500 PSI or 3.4 MPAM Minimum the ICP should steadily climb during cranking. This indicates a healthy HPOP depending upon how high it climbs. It should be between 480 - 520 at idle.
ICPv (KOEO) Spec 0.20v - 0.30v This is important to check KOEO to verify the sensor is within range electrically.
FUEL PW: 1 MS - 6 MS (<1 / >6 IDM Suspect)
DC% - Cranking NTE 20% / 65% is closed. (IPR Suspect) 10% - 14% at Idle.
Low RPM's could also be an indication of starting / charging system problems which is drawing engine RPMs down when your coasting to a stop.
FUEL PW - Even though a 1 to 6 mS FUEL PW is shown, it’s possible the IDM did not receive the signal due to a CI or FDCS circuit fault or internal IDM failure or communications failure between the IDM and FP.
Hope this helps,
Tom
Hope this helps,
Tom
reggiedunlop
1983 - 2012 Ranger & B-Series
11-04-2016 10:42 AM
sancochojoe
22
07-19-2006 07:36 AM
jfor26
10-27-2005 08:41 PM
