Computer swap issue...Fuel pump stays running
Previous Post on computer swap:
https://www.ford-trucks.com/forums/1...2-f-150-a.html
Well I received the used 5.8L Computer today for my 5.0 to 5.8L swap. I decided to go ahead and hook it up to test it on my 5.0L that is currently in the truck just to see if it works..
Here is the issue.
When I turn the key on, "engine off." The Fuel pump stays running and does not shut off. IT just stays priming the pump. That whining noise you here for a short moment... It just stays going... Is that normal? I don't think it is...
It cranks and runs the 5.0L engine, "but the check engine light comes on about 2 seconds after start."
I removed the 5.8L computer and reinstalled the 5.0 computer to make sure it was not another issue...The fuel pump turns off after a moment and the check engine light is not on when running...So....
I just wanted to ask you guys to see what you all think. Thanks
Here is the issue.
He or she sold you a junk yard PCM, has no clue if it even worked right, and doesn't know 1 THING about the item they are selling!
As RLA pointed out, there is NO flashing needed on this vintage PCM and its NOT a Chevrolet/GM PCM!
Tell him your PCM works fine and you bought this one as a spare. The seller doesn't need to know what your Catch Code for the PCM is. When they state, "It may need to be flashed by the dealer" they don't know diddly about these PCMs we are dealing with. Demand your money back! Open a complaint file immediately! Get the ball rolling.
Let us know who the seller is. I'm curious and want to see his or her feedback.
If they we want your Catch Code for the PCM, then just tell them its the exact same as the one I bought!
I went to the Local Ford Dealer and talked to one of the techs....He said that some of those older style OBD1 computers had a continuous loop circuit for the fuel pump for heavy duty use similar to the 460 big blocks. After a few minutes of talking and explaining that it does not shut off with KOEO at all.
He then said, "Although it should shut it self off after about 30 seconds." The only way to know if it is bad is to test it.
I tried again to see if it would shut off and the fuel pump continued to run with KOEO...
I went ahead and sent the computer back...
The seller is sending me another one...The seller said, "I know for a fact this is a good computer I am sending you." He has been pretty cool about the issue I am having with it.
Glad to see the issue was resolved.
FYI.
You may want to check the capacitors in that PCM before trusting it indefinitely. I would check the 5.0l PCM too. And while your not using it, just get those capacitors replaced. It'll be worth its weight in gold, if this 5.8l PCM starts giving you problems and then turns your project into a boat anchor.
FYI.
crimsonchin
05-17-2009 04:48 PM
corvette99
09-21-2008 03:51 PM
