Code 13 and 24 same time ...
Wonder if any suggestions on where to start with these dual codes ? Attempted to look in the intake, clean but no change for the air temp sensor, might be simply time to replace .... just wonder if there's much history of this one ? Speed density 5.0 92 vintage ....
Let's step back a few steps....
Why are you running Key On Engine Running (KOER) tests? You should ALWAYS start with the Key On Engine Off (KOEO) test and stored code display.
1991 was the transition from two digit to three digit codes. Depending on what engine/transmission you have you could have one OR the other in 1992. Please list your vehicle details so we can assist you with an accurate diagnosis.
Code 13 is KOER only (Cannot control rpm during Self-Test low rpm check). I DID NOT CHECK WHEN TRUCK WAS RUNNING
My 1992 Ford truck service manual shows Code 24 is KOEO or KOER, not a stored code. OK, but in a prior post you (or someone) indicated 2 different systems during 92
How are you checking the codes? Counting flashes or using a code reader?
COUNTING FLASHES
What transmission does the truck have?
COUNTING FLASHES
Since this is an engine issue, what difference does it make which trans ?
