Compression check now won't start
Just wondering what I may have broken ? Did a compression check on one car then moved on to my truck 92 f 150 5.0. So, did the same thing as the car, took the wires going to the coil - disconnect incoming and coil wire to distributor, removed all plugs and performed test. Turned out good, between 150 and 165 on all the cylinders. Put it all back together and now it won't fire, cranks just fine.
So, what did I forget or mess up in the process ?
JRS2
05-14-2014 09:51 PM
dylansf23
30
11-30-2013 07:38 PM
bountyhunterjp
07-31-2004 10:44 PM
