Compression check now won't start
Old 06-28-2015, 11:30 AM
JRS2's Avatar
JRS2
JRS2 is offline
Just wondering what I may have broken ? Did a compression check on one car then moved on to my truck 92 f 150 5.0. So, did the same thing as the car, took the wires going to the coil - disconnect incoming and coil wire to distributor, removed all plugs and performed test. Turned out good, between 150 and 165 on all the cylinders. Put it all back together and now it won't fire, cranks just fine.
So, what did I forget or mess up in the process ?
Old 06-28-2015, 07:38 PM
JRS2's Avatar
JRS2
JRS2 is offline
I got it. Contacts for the electrical connection into Coil needed cleaning ..... since I only touched a couple things, it didn't make logical sense something else should go, but you never know ..... sometimes it's just not your day ....
Old 06-28-2015, 10:58 PM
dixie460's Avatar
dixie460
dixie460 is offline
Glad you got it figured out!
JRS2
05-14-2014 09:51 PM
dylansf23
30
11-30-2013 07:38 PM
khadma
General Automotive Discussion
09-30-2012 08:39 AM
Roy C
11-01-2010 10:51 AM
bountyhunterjp
07-31-2004 10:44 PM
Quick Reply: Compression check now won't start
