Ignition wiring issue
Old 06-20-2015, 08:27 PM
gtotiger65's Avatar
gtotiger65
gtotiger65 is offline
I recently purchased a 1950 Ford F3 with the original 6 volt flathead V8, and I need some ignition wiring help. I put a new 8 volt battery, starter solenoid, battery wires, and checked the starter.
Could someone tell me the correct wiring for the starter solenoid. The engine will turn over (not start) from the solenoid button, but not from the ignition button (no click). I have it wired as follows: battery positive to engine block, battery negative to passenger side of solenoid, ignition button to front of solenoid, other wire from ignition to driver side of solenoid and then starter wire from driver side of solenoid. I have also replaced the fuel pump, fuel filter and fuel lines, but I am not getting any fuel to carb. Any ideas and help will be appreciated. Thank you!
Old 06-20-2015, 08:34 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
The starter button on a '50 should have a single terminal and grounds to the dashboard sheet metal. Pop it out and make sure the metal clips that hold it in the dash are clean and so is the dash where they clip in. You can ground the wire at the switch to test the wiring.
Old 06-21-2015, 01:35 AM
FortyNiner's Avatar
FortyNiner
FortyNiner is offline
Did you follow this diagram? http://www.vanpeltsales.com/FH_web/F...48-49truck.jpg
On the fuel issue, what is the condition of the tank? Were all tank connection fittings clear of crud?
fyredude
1999 to 2016 Super Duty
15
07-15-2016 01:56 AM
71mach351
05-18-2014 02:42 PM
will2045
10-01-2011 08:26 PM
floppywater
01-02-2011 10:17 PM
roger dowty
10-23-2006 01:47 PM
Quick Reply: Ignition wiring issue
