Best way to press out old steering link ball stud?
What is the best way to get the old ball out of my steering arm so i can put a new one in. Do I need to cut off the ball and drill a hole in the stud to relieve some of the tightness. i have soaked it several times now. I made a remover out of 2" rectangular tubing and slotted the top to go around the ball and drilled a hole in the bottom of it and welded a 1/2 nut to it so I could use it to push the stud out. That is not working it is bending my bolt. might have to pull the whole arm and take it to work and put in a hydraulic press. If anyone knows a way to do it at home , I would sure appreciate the advice.
Thanks,
Oscar Shearer
Thanks,
Oscar Shearer
I just did this. The ball in the U shaped arm is swedged(mushroomed) in the hole. Remove the arm to work on it.
I drilled a 5/8 hole from the back about 1/2" to 3/4"deep. Ground flush. Held firmly in a good vise, heated the arm around the ball with torch and drove out with a drift punch and BFH. Still came out hard.
I would have used my press, but there is really no way to hold it square in the press.
I heated the arm again to press the new one in. Welded the back side.
I'm not sure that I would be welding on a forged steel steering part. Here is a note from the millerwelds.com forum:
how to identify between cast steel and forged steel. & then the best way to weld it
And here is a thread from H.A.M.B.
Welding forged steel | The H.A.M.B.
It can be done but with extreme care and experience. The results of an error would be catastrophic.
fishjosh
18
07-16-2018 03:21 PM
tonygray
09-23-2007 05:30 PM
