7.3 IDI front driver-side lift point
Old 06-17-2015, 10:28 AM
IDIoit's Avatar
IDIoit
IDIoit is offline
i use 4,
on each corner intake runner.
then attach my load leveler.
makes things super easy.
Old 06-17-2015, 01:40 PM
irhunter's Avatar
irhunter
irhunter is offline
OK, will do. Super easy is what I'm after.
Old 07-14-2015, 10:35 AM
irhunter's Avatar
irhunter
irhunter is offline
OK,
I used four, also.
I made a bracket for the front/driver-side out of angle. I just used one manifold bolt (using the stock bolt which came with the engine), and it seemed to work fine.
As a side note: 2-ton Performance Tools lift with a Neiko 8-ton ram worked fine (using the 2-ton arm extension setting)
Old 07-22-2015, 11:35 AM
lgfuller's Avatar
lgfuller
lgfuller is offline
those bolt holes are from international. they are where the air compressor mounts on an air brake truck. also very useful for the idi turbo motors to hold the air filter housing...
Old 07-22-2015, 12:20 PM
irhunter's Avatar
irhunter
irhunter is offline
Thanks. I have come to the conclusion the holes are used for several purposes in various trucks and vans.
Grat123
07-17-2013 04:49 AM
rangergirl94
05-22-2012 06:10 PM
BombThreat
02-02-2008 04:03 PM
fsdog63
09-24-2005 12:46 AM
Quick Reply: 7.3 IDI front driver-side lift point
