Lift help
Old Jul 16, 2013 | 05:23 PM
Grat123's Avatar
Grat123
Lift help
I have a 93 7.3 idi with I beams and wanted to know if there's any lift kits out there? Not extreme crazy lift just a solid level. Maybe 2 or 3 inches in front is all. Can't find anything anywhere. Was wondering if someone could shine some light thank you .
Old Jul 16, 2013 | 06:41 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
2wd or 4x4?
2wd.....the trouble is not worth the couple inches...re-bending beams....finding a GOOD alignment shop
4wd....they make lift kits, but i would just do a D60 swap. better(stronger) axle and will get you the lift you are looking for.
'94IDITurbo7.3
double post
Old Jul 16, 2013 | 10:44 PM
Grat123's Avatar
Grat123
It's 2wd but there's nothing I can do to lift it without messing with everything? Cuz if a 2 inch lift needs bending I beams than screw that ill maybe lower the back and put 33s on. And repost? I read that there's a diesel van that has my coil springs but just a little taller?
Old Jul 16, 2013 | 11:02 PM
garthneddy's Avatar
garthneddy
You should be able to get away with a mild lift without needing bent beams, but my knowledge is based solely one experience with TTB. I've leveled 1/2 ton and 3/4 tons and was able to get them aligned with nothing more then adjustable camber bushings.
Old Jul 16, 2013 | 11:21 PM
Grat123's Avatar
Grat123
Ok I found a 1 inch lift on ebay for pretty cheap I think I'm going to do that just to pick the front up at least an inch and than put 33s on. Do you think they will rub?
Old Jul 17, 2013 | 01:49 AM
garthneddy's Avatar
garthneddy
I have no clue as I've only run 4x4s, but as long as you own a sawzall you can make anything fit
Old Jul 17, 2013 | 04:49 AM
tjc transport's Avatar
tjc transport
i ain't rite
i would get new springs. the ones on it are probably shot, and that ebay 1 inch kit is a shim you put under the spring. not a very good idea.
SoCalAngler
Jul 14, 2014 09:52 AM
Shwan_89HD
Aug 28, 2012 06:50 PM
05f250fx4
Aug 22, 2006 11:16 PM
fsdog63
Sep 24, 2005 12:46 AM
