Side Gapped Spark Plugs? Do they work?
Old 03-04-2002, 09:59 PM
Pastmaster's Avatar
Pastmaster
Pastmaster is offline
Old 03-08-2002, 03:19 PM
sam_1857's Avatar
sam_1857
sam_1857 is offline
I've read alot throughout these message boards re: side-gapped plugs. Have also seen most people suggest using the MotorCraft plugs designed for a specific vehicle. I have a 95 F-150 SC, Inline 6, 123K. I avg 15mpg mixed driving. I'm about to get new plugs and am leaning toward the MotorCraft plugs.
However, I wonder if side-gapping plugs is worth it. Does it improve gas mileage and power? Can it damage the coil or module?
Mechanics I've talked to have never heard of it.
Thanks,
sam_1857
Old 03-08-2002, 09:27 PM
Redneckerson's Avatar
Redneckerson
Redneckerson is offline
I haven't used this in any of my trucks (1990 Bronco &1991 F150) but my roots go pretty deep into the mustang world. I have a pretty hot 5.0 (actually 307cid now) which has 333 brake horse power verified by some really expensive dyno time and I picked up 7 HP by side gapping (but it was up top 4500-6500 rpm)!!!! I was running a 226 degree duration .512 lift roller cam w/110 degree LCA,10.5 to 1 and MSD everything which I'm sure helped with the ultimate Hp. It seemed to help the idle quality which was fair at best with the cam I'm running but like I said earlier the power only showed itself up top. I was told due to the cam overlap it really paid off to side gap since it exposed the spark to the incoming charge. I'm not sure how much it will help us in the truck world since most of us are looking for low end and not ultimate hp in the upper RPM's but there are some tricks out there to free up some HP. I suppose it depends where your priorities are- i.e. high end hp or low end. I hope this helps more than confuses. Regards
Old 03-09-2002, 07:42 PM
1-ton's Avatar
1-ton
1-ton is offline
I "side gapped" the last set of plugs I installed in my 90 351. I didnt really notice a differnce in performance, however, after about 8-10,000 miles it started to burn out the plugs:-X23
Old 03-09-2002, 08:01 PM
Pastmaster's Avatar
Pastmaster
>the plugs:-X23
I tried em with a set of autolites a couple of years ago and I didn't notice anything either. Mine wore out in less than a year too.
'93 F-150 loaded and modified!
Check my Gallery
Old 03-10-2002, 05:03 PM
71mustang's Avatar
71mustang
71mustang is offline
What is side gapping the spark plugs?
Cody
Old 03-10-2002, 05:36 PM
fourtrax's Avatar
fourtrax
fourtrax is offline
side gapping is where you remove part of the plugs gounding electrode so that the center elctrode is exposed. unless you just want to play with a hacksaw bosch has side gapped plugs with 2 or 4 electrodes.
You can side gap any plug but it will cut the live of the plug in half. Bosch has added extra electordes to maintain normal life of the plug. hope this helps.
http://www.boschusa.com/AutoParts/SparkPlugs/Platinum2/
http://www.boschusa.com/AutoParts/SparkPlugs/PlatinumPlus4/
Old 03-10-2002, 06:20 PM
71mustang's Avatar
71mustang
Thanks!
So it is kind of like the splitfire plugs I am using.
Cody
Old 03-10-2002, 07:15 PM
gamehunter's Avatar
gamehunter
gamehunter is offline
I was wondering the same thing so I side gaped a plug and put it in my 4 wheeler. It runs smoother and has a little bit more power after I added the new plug. It also seems to start better possibly because of added spark. What I did was cut off part of the electrode with a cut-off wheele on a dremel tool. It is real easy and I think I might try it on my truck next.
bryanknie
85
10-16-2022 12:43 AM
truck7575
08-02-2015 09:53 PM
gearheadmb1
New Member Introductions
01-25-2015 06:41 AM
bigcountry62
16
04-26-2013 12:52 AM
autotech
09-18-2000 01:23 PM
Quick Reply: Side Gapped Spark Plugs? Do they work?
