NP435 fastener torque specs
I have been searching here and all over the web for torque specs for my gearbox. I am resealing/gasketting it and want to make sure I am tightening all the various bolts correctly.
This is a 1970 F250 4x4 if that matters, but I reckon not?
Top cover
PTO cover
input shaft cover
output shaft cover
Counter shaft thrust bearing cover
I have the Chilton manual for the truck (1965-86) and I downloaded the rebuild manual for the 435, but neither have those specs....
Thanks,
Tim
Top cover
PTO cover
input shaft cover
output shaft cover
Thanks,
Tim
on
TQ for most all SAE bolts sizes is the same. So look up the bolt sizes and you've got it.
This is in all auto manuals.
If you don't have the yoke shaft seals for the yokes just use some RVT under the washers on the 3 yokes.
Grade 8 bolts with fine thread uses max TQ where as course thread is minim.
Orich
Orich
Top cover
PTO cover
input shaft cover
output shaft cover
Thanks,
Tim
Top cover
PTO cover
input shaft cover
output shaft cover
Thanks,
Tim
Piston Honda
09-27-2013 05:34 PM
LUMBERMAN
09-17-2006 05:18 PM
