6.2L V8 Discuss the 6.2L V8
Help identify wiring harness/plug
Old 06-02-2015, 11:45 PM
PokerMunkee's Avatar
PokerMunkee
PokerMunkee is offline
'11 F-250 6.2L. Just bought it. Found this guy dangling down by the front driver side shock.
Any idea what it is?
Also, what is this? Located on front lower bumper. Jump start port?
Old 06-03-2015, 10:16 AM
Super Duty DJ's Avatar
Super Duty DJ
Super Duty DJ is offline
The first connector, I have no idea what that is, but you may be able to figure it out by tracing it back to its source. The second connector in the lower front bumper is a quick connector that is typically used for a removable winch or something similar.
Old 06-03-2015, 01:25 PM
PokerMunkee
The wire ends up going into the main wiring harness up into the engine area (front driver side). It has 105 and 360 printed on the end of the orange plug.
I'll get under it more tonight when I get home.
Old 06-03-2015, 05:21 PM
Mike in PA's Avatar
Mike in PA
Mike in PA is offline
Hey Poker,
That looks like the plug for the block heater. If you crawl under and look up you will see where it plugs in.
Mike
Old 06-03-2015, 10:55 PM
PokerMunkee
Originally Posted by Mike in PA
Hey Poker,
Mike
Thanks! That was it. Found a spot on the block to plug it in. Doesn't seem to lock in there tight. Hopefully doesn't come out again, will keep an eye on it.
Ifirefight
2017+ Super Duty
01-10-2018 03:42 PM
blu89
06-24-2015 04:27 PM
catbird7
Electrical Systems/Wiring
07-11-2011 10:03 AM
Boss_358
05-24-2010 03:32 PM
whitesdford
03-07-2010 10:34 PM
Quick Reply: Help identify wiring harness/plug
