A question for Mark Kovalsky about 5r110 trans
Hi Folks, I had a Jasper transmission installed last year and have done 6k miles on it. Recently I have a high pitched noise coming from the transmission. I jacked up the back wheels and turned the rear wheel and there is a sound like a dry seal, sort of a squeak, not real loud. It is there but not loud when I drive, until I reach 70 mph. At 70 it is quite loud an sounds like a very high pitched gear whine. Any ideas would be appreciated before I have to go through this ordeal again.
The transmission works perfectly, shifts great, there is good color to the fluid and it is full.
Thanks, Andrew.
Thanks, Andrew.
Thanks Mark for chiming in, yes I will pull the drive shaft and check closer about that front u joint. It looks good, feels good, but may be as dry as a bone inside. Appreciate you telling me that there's nothing in the transmission that would make that noise, comforting for sure. Thanks again, I will let you know what I find out.
Andrew.
Andrew.
Mechanics Stethoscope maybe? Never had a U-joint go that way on our fleet. They silently begin vibrating at 3-4 times an out-of-balance tire vibration frequency that you notice in the seat around 40mph and up. Invariably the differential side joint goes bad first. I haven't seen everything, but about a half dozen or so of these all going this way.
drunkdave
09-09-2009 07:35 PM
