1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Wiring woes
Old 05-22-2015, 08:41 AM
Vinford's Avatar
Vinford
Vinford is offline
Wiring woes
2005 F-350 diesel
When I first got it the radio was shutting off by its self, my 02 did the same thing so I wasn't to worried about it.
But things have advanced , radio shuts off , windows wont work?
Goes on and off at will , does not seem to be road bump related as they go off and on when Im not moving.
Will stay off until I restart truck sometimes and other times it only stays off for a few minutes.
Anyone got any ideas?
Old 05-22-2015, 09:24 AM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
Just spit-balling, but does it have an accessory delay relay? That's one thing that does tie radio and windows together.
Old 05-22-2015, 11:05 AM
Vinford's Avatar
Vinford
Vinford is offline
Yes it does.
I forgot to mention it seemed to get worse after I washed truck.
I didn't spray water anywhere that should have made a difference.
Old 05-22-2015, 10:20 PM
Vinford's Avatar
Vinford
Vinford is offline
I just noticed all the gauges , tach etc also quit when this happens
Old 05-23-2015, 04:16 AM
tripplej's Avatar
tripplej
tripplej is offline
hello, my2005 ford f350 superduty is doing that and now i'm at a loss, as I just baught my truck in jan. of this year.
been doing a lot of reading and some say to check the ignition switch,and the neutral switch on the stearing colum,and to check the batteries,the fuses,and to check the fuse box under the dash that a pin could be making a bad connection.and to check the starter etc.first time owning a ford,don't know what to do except listen to those who know more about this electrical problem.
Old 05-23-2015, 06:19 AM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
Just a test to try, next time everything goes out tap or slap the top of your dash above the gauge cluster. That is where a battery saver relay (or some relay like that) is located that powers most of these things and has been found to be the fault of this problem a few times.
Old 05-23-2015, 08:44 AM
iamrfixit's Avatar
iamrfixit
iamrfixit is offline
Originally Posted by Vinford
Yes it does.
You likely have water leaking in around the windshield and getting into the fuse panel and possibly other electrical components under the dash, been a pretty common problem with these trucks.
Old 05-23-2015, 09:20 AM
Vinford's Avatar
Vinford
Vinford is offline
I smashed the top of dash the other day I was a little frustrated......radio came back on.
I hit it pretty hard , not sure if it was a fluke or it jarred it on again.
Is it a replaceable part?
Water leaking around the windshield? What to do with that?
I can probably get windshield sealed but what is the water getting on to cause short?
Old 05-23-2015, 04:17 PM
Snowseeker's Avatar
Snowseeker
Might be able to get away with a good clean silcone glue job to seal a leaky windshield.
The relay up in the dash is in the gauge cluster and it is said the whole cluster needs to be replaced to fix it. I couple others have torn into the cluster, one I remember saying the solder joints around the relay were bad and I forget what the other did.
Old 05-23-2015, 04:57 PM
Vinford's Avatar
Vinford
Vinford is offline
Im not to worried about sealing the window , but that wont fix whatevers wrong.
Old 05-23-2015, 09:28 PM
iamrfixit's Avatar
iamrfixit
I would do some checking and see if you can find signs of water. Have heard water gets into the fuse panel as well as other things. In my experience getting the water stopped, blown out and dried out may cure some of your problems, other issues may require some new parts. Most important thing is get the water stopped first.
My windshield got replaced when the truck was only a couple years old so thankfully I haven't had problems with leaks, but plenty of others have.
If it were mine I would have the windshield replaced or cut out and resealed. I have never had much luck with trying to seal a leaky one up. Bought a new 94 Dodge and went around and around with the dealer to get leaks stopped in both the windshield and rear window. After about 6 tries and failures by the dealer, I took it to a glass repair shop where they cut the windows out and reinstalled them.
Old 06-01-2015, 07:49 PM
tripplej's Avatar
tripplej
tripplej is offline
thanks for the reply, got a red seal mechanic looking at it. gauges work now,signal lights work now, radio works now.
it had a remote start in it and an after market alarm system that was toast.
my mechanic riped all that junk out and put the wiring back to factory state.
OnlySS
09-17-2016 05:10 PM
papajoemrt
1997 - 2003 F150
02-11-2010 05:15 PM
Badfish740
03-29-2007 11:33 AM
Greywolf
Tennessee Chapter
24
08-08-2006 08:28 PM
dbossman
Electrical Systems/Wiring
12-28-2004 08:48 AM
Quick Reply: Wiring woes
