I have a noise in my rear end, if I grab the bed of the truck, and rock the body back and forth, I hear a clunk, almost sounds like a wheel is loose, but checked them, all good, also checked the U-joints, and pulled the driveshaft to grease the spindle. Thinking it could be in the third member, maybe the Differential pinion shaft, or the lock bolt......any suggestions, or help would be appreciated.
