Replacing pass side freeze plugs w/ pics
Has anyone used these before?
I have the 3 on my passenger side of block not looking too healthy but not leaking yet, I've done some reading that these are a permanent alternative to pressing/pounding in new plugs with the engine out.
Dorman Products - 02482
Here's a link, these are NOT the rubber expandable ones
Roughly $6 a piece from what I've seen but hey if I don't need to pull the engine and strain my back these work for me.
I just put brass freeze plugs from NAPA in my 460. Cleaned things up real good and put them in with Loctite 648.
I pulled my motor also. But I had a rear main seal leaking and I needed to do some exhaust manifold work too. It was the right way to do it. Now I have ZERO drips on the garage floor!!!
Todd
Todd
I worked at a machine shop for a while where one of my major duties was dissembling and stripping engines. I've removed maybe thousands of freeze plugs. The key to getting them out easily in one piece is twisting them in the hole and NOT pushing them in. I use a rather large chisel that I blunted and put a slight curve on one side so it fit in the corner of the cups dish. I would then tap in one corner to twist it in the hole until the cup lifted out on the opposite side. I'd then grab that side with vise grips and use the curved side of the vise grips like a pry bar against the block and pill it right out. This method only failed to take them out very easily when the blunted chisel broke through the cup before it freed up from the block.
Is it a pain getting the flex plate and torque converter studs aligned when reinstalling the engine? Roughly how long did this take you start to finish?
I had the truck down for about 3 weeks working a few evenings a week and I did a few other things. If I were doing just the freeze plugs and rear main I could have been done in a week easy, not using any vacation days.
Todd
Thanks for the responses guys. I am going to start working on this tomorrow.
Can anyone tell me if there is an o ring on the engine oil dipstick TUBE where it goes into the block? Or is it just pressed in with nothing? Mine is really rusty and I'm sure it's going to snap when I try to replace it, just want to understand what I will be up against when I am removing the remaining portion that is still passing through the block.
Well I ended up leaving the driver side plugs as they were all in excellent shape which is odd because on my 97 460 my driver plugs were in good shape while the passenger side all rotted. I ended up going to napa and bought the deep dish style freeze plugs, unfortunately no one around had deep dish brass plugs so I bought the steel.
I didn't pull the engine, when my cab swap was done a 95 f150 2x4 cab was used not knowing the transmission hump was different so a 3" body lift was installed so the cab would work. This gave me extra clearance for doing this. I loosened the transmission mount and driver side mount, I then removed the pass motor mount and jacked the engine up.
Here's some pictures.
Drop lower rad hose...... kinda missed the bucket
Pull the starter
Old plugs, the rearmost toward the starter was the worst I pushed my finger through it.
Tap in with blunt punch until it pivots sideways then remove with channel locks using the block as leverage.
Was happy to find this.
New plugs installed with a quick coat of engine enamel over them for corrosion resistance, used various sized hammers and a deep well 15/16 socket along with a stubby of the same size. Don't mind the brake hose, for some reason the tire started rubbing it.
All done,
The reason I did this was to get the truck on the road asap, I don't have a week of down time to pull the engine and replace this and that, this took me roughly 3 and a half hours from start to the end of cleaning up the floor.
I'm sure someone in the future will have this same problem and will find this thread hopefully showing an alternative to pulling the engine.
Pull the starter
All done,
Nehmo
04-18-2019 06:40 PM
irvdog63
04-06-2018 09:02 PM
Mamaof7
10-20-2013 12:56 AM
