New member here. I have a 03 7.3 limited with power adjust pedals. Throttle position sensor starting to go, can TPS be replaced without replacing entire pedal assembly? How to remove pedal assembly.
If I recall correctly, the adjustable units have the sensor integrally built into the entire setup. I've not removed one of those, but I've done the others twice, and am hoping my adjustable unit in my Excursion does not go out before I sell it.
