Bought a flat bed - need to make it a car hauler
Old 08-10-2015, 01:16 PM
87crewdually's Avatar
87crewdually
87crewdually is offline
Originally Posted by Turbo Dog
I opened the first hub last night to get a seal number. I've seen a lot of talk about different style of hubs...which style is this? I'm going to repack all of them before my trip because I bought the trailer used. The grease and bearings are in good condition, but I'll feel better if I repack them.
Looks like Dexter EZlube axles or some variation of. Use a manual hand pump grease gun with a high quality bearing grease.
  #32
Old 08-10-2015, 02:49 PM
senix's Avatar
senix
senix is offline
Received 1,417 Likes on 1,012 Posts
spin the wheel as you pump...but not too many pumps of the gun.
  #33
Old 08-24-2015, 12:59 PM
Turbo Dog's Avatar
Turbo Dog
Turbo Dog is offline
Thanks for the explanation but I tore all the hubs down and greased the bearings by hand and installed all new grease seals.
  #34
Old 08-31-2015, 04:56 PM
Turbo Dog's Avatar
Turbo Dog
Thanks for all the input
I towed the trailer with my F100 on it from Laramie to Detroit and back without any problems. My F150 5.0 FX4 got 11.3 mpg heading east which is slightly downhill with a slight tail wind, then it got 10.5 coming back west going uphill and into the wind. I was glad I put the new tires on the truck when I hit a tremendous downpour coming back. The road was covered with water and I slowed down because I could only see about 20 yards. That amount of rain didn't seem to phase others who came flying by me, so I ended up with the flashers on to help others realize I wasn't a full speed.
Next time I would skip the E-Tracks and use a wheel net or strap around the suspension.
  #35
Old 09-05-2015, 11:14 AM
351Cleveland C4's Avatar
351Cleveland C4
351Cleveland C4 is offline
When I haul a vehicle, I usually go around the axle(s) and then I also strap the body/frame down as well if possible. It keeps the vehicle suspension from bouncing and tossing weight around.
Like on a pickup, big straps over the axles and then the smaller 1-1/2" 3,000lb straps to pull the frame down. This also loads the suspension and helps keep the tires planted on the deck.
  #36
Old 09-22-2015, 09:35 AM
Turbo Dog's Avatar
Turbo Dog
Yeah, I noticed that the body was almost constantly bouncing around a little bit. I think it finished off the shocks while sitting on the trailer...they were looking and feeling a bit soft already. I think your idea of also strapping down the body would have helped.
Thanks
  #37
Old 11-21-2015, 06:36 PM
Kevin Kanzler's Avatar
Kevin Kanzler
Kevin Kanzler is offline
Axle almosts looks like someone tried to make a normal axle an ez lube or an imitater. Unless dexter changed their design for the 7k (heaviest dexter I've greased is a 6k)
Tow straps should be fine but my dad had one break on him before towing a car. So he always used chains. So I always use chains if its on a flatbed and has tires.
also strapping down from the frame will stop the body roll. Not a big deal there are advantages and disadvantages to each from what I understand. The AAA trucks and others normally use a chain or 2 and i think they go from the tires and control arms. I go with whats easiest, normally/ hopefully the frame
  #38
Old 02-20-2016, 08:32 AM
jetjockey99's Avatar
jetjockey99
jetjockey99 is offline
Remember also that while the tires are rated for 12K they are not carrying 100% of the load, the tongue is also carrying weight so you do have some leeway.
  #39
Old 02-20-2016, 08:43 AM
jetjockey99
Those E-Tracks are not designed for the use you are putting them to. I have seen them tear out from a lot lighter load than you are using them for, they can handle enough weight but they do not take shock loads well and using them as tie downs you will have significant shock loads on them. I have seen them tear out when used in trailers when the load was not strapped quite enough with less then a 1K skid that tipped sideways and that was not even close to their capacity.
  #40
Old 03-11-2016, 07:16 PM
Rovernut's Avatar
Rovernut
Rovernut is offline
I don't feel like the E-Track setup let me down, I just noticed that the truck moved backwards a little. The front chain should stop that.
The test isn't normal towing, it's what happens during emergency maneuvers, sudden;y really rough road or in the event of an accident
Benztechnc
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
17
04-19-2016 12:47 PM
sawboy
06-19-2007 05:43 PM
Dome
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
12-11-2005 01:20 PM
AzPete
07-25-2005 07:05 AM
VR666
16
08-14-2004 09:24 AM
Quick Reply: Bought a flat bed - need to make it a car hauler
