Gauge cluster and circuit board questions (lots of em!)
I'm thinking the circuit board on my cluster is hashed. I made sure my wires were all plugged in and grounded properly, but I'm not getting any reading off either fuel tank or my temp gauge. Though the ALT idiot light comes on when I go to start the truck, so at least that one works. Am I right in thinking the board is done for? Or should I look elsewhere? If it is the board, how does a guy go about sticking a new one on?
For the cluster itself, I'm not too big on spending the bucks for a new one, so I'm going to refurbish the one I have. How can I clean up the yellowed plastics over the gauges? Also, is there any special way to remove the Speedo cable from the cluster, or just loosen a nut and slip it out?
Sorry for the barrage of questions guys, but this is my baby and I want her perfect! Haha
1970 F100/350 printed circuit boards are 1970 ONLY and there are two different types.
D0TZ-10K843-A .. Printed Circuit Board-Use with Oil & Amp GAUGES / Marked: D0TF-10C956-A / Obsolete ~ Available NOS
D0TZ-10K843-B .. Printed Circuit Board-Use with Oil & Amp WARNING (IDIOT) LAMPS / Marked: D0TF-10C956-B / Obsolete ~ Available NOS
hmmmmm...
Thanks for the info Bill, I'm really hoping I'm not going to have to hunt one down but that is going to be my favorite post on the whole forum if I do have to.
I pulled the cluster out to check out the board and pull the ICVR, and I found some interesting things
45 years of filth built up
The board doesn't look all mussed up though...?
Where the wires and such plug into the cluster, the left side is separating from the metal underneath. I wonder if it couldn't be stuck back down? Or just leave it and let the pressure from the clip on the plug keep it down?
This is my main concern. The little connecting strip over the ICVR is disconnected. It isn't damaged in the slightest, but it is pulled off. Could this also be somehow reconnected?
Nice and clean now though. The parents weren't entirely happy about it getting done on their dining room table, but it'll buff out hahaha
As for the ICVR, how does a guy go about pulling it off? I'm worried about hurting the board stuck to it
Arizona97
12-20-2017 05:35 PM
rjohnson_15
12-25-2012 09:42 PM
Black Jack G
12-10-2011 12:30 PM
