The circuit is interupted some where between the fuse box and the plug if all fuses have power. Like I said it actually has to get there. My circuit diagram shows no relay involved so that eliminates that possibility.
check the fuse holder with a meter to verify power is actually there. And then check the fuse with a meter. It could pass power but not all the power. Then starting at the pump, work toward the fuse box checking the wire as you go.
