Belt issue?
Old Apr 3, 2015 | 08:57 PM
tbax46's Avatar
tbax46
Belt issue?
I think I know the answer but thought to check with the knowledgeable here. Had a no start crank. All numbers on scan gauge ruled out oil pressure and FICM. Batteries not putting out enough so I put the on a charger for three hours, then got a good start. Decided to check alternator and got 12.25!reading. Not good but reved up to 2000 tons and got 14.45. I'm guessing slipping belt unless you guys have another scenario.
Old Apr 3, 2015 | 10:35 PM
firedaniel's Avatar
firedaniel
Have your batteries load tested and change your alternator. Replace the belt while your at it. You could have the old alternator tested too but if it's stock I would just replace it.
Old Apr 3, 2015 | 10:46 PM
78fordman's Avatar
78fordman
I don't think you have a belt slipping issue. More an alternator issue.
Old May 6, 2015 | 05:49 PM
tbax46's Avatar
tbax46
Correct guys. It was the Altenator.
vroom9
Aug 2, 2020 10:18 AM
rpenterics
112
Oct 27, 2016 09:07 PM
WalterRoad
Aug 1, 2014 04:45 PM
Shepherd Taxi
15
Jan 7, 2010 10:08 PM
optikal illushun
13
May 2, 2009 03:57 AM
