Painting the interior of my cab
Old 05-06-2015, 10:08 AM
Melnickta's Avatar
Melnickta
Melnickta is offline
This is my first attempt at painting anything "automotive" related. Had no idea prep work would take this long. The sanding/bondo took a while, but the masking took 2-3 hours longer than anticipated. I hope all of this work will pay off.
I'm spraying with rustoleum automotive primer then many coats of the duplicolor paint shop white and finishing with matte clear. I'll have 12 hours into the interior paint when it's all said and done.
Old 05-06-2015, 07:43 PM
oldracerjones's Avatar
oldracerjones
oldracerjones is offline
Pictures? Getting ready to do mine, have to finish disassembly and get it blasted. Any tips will be appreciated.
Old 05-06-2015, 08:21 PM
Buzz44's Avatar
Buzz44
Buzz44 is offline
Before and after rattle can interior paint. My wife did the seat cover, door panels and carpet.
This is when the truck hit my driveway.
This is after a rattle can job and a good used steering wheel along with some good used door step trim. Lots of sanding and fill sand helps the paint. I did screw up and when I thought I was painting another coat of primer I actually had a can of satin paint in my hand. Kind of screwed the paint job up but I went with it. Doesn't look to bad but it would have come out better.
Old 05-06-2015, 08:27 PM
jmf66's Avatar
jmf66
jmf66 is offline
Remember the finish will only be as smooth as the primer underneath. Spend most of your time on getting the primer slick and it should turn out ok.
I've had the rattle-can clear yellow after time. The white here is Dupli-color's Wimbledon White with no clear.
Old 05-08-2015, 10:32 AM
dnsenne's Avatar
dnsenne
dnsenne is offline
Hey Buzz,
Where did you get those sill plates to cover up the edge of the carpet?
Old 05-08-2015, 08:03 PM
Buzz44's Avatar
Buzz44
Buzz44 is offline
Originally Posted by dnsenne
Hey Buzz,
Those came out of a 64 CC at the local pull and save. Those might be a 64 option only as I have never seen them in any year 61-63. That is just a WAG on my part as far as the years available. I have only seen them in 64s.
Old 05-08-2015, 08:12 PM
dnsenne's Avatar
dnsenne
dnsenne is offline
Wow. Thanks. I haven't seen any at the salvage yards I have been to so far...
Thanks for the great info.
Old 05-09-2015, 05:57 AM
Melnickta's Avatar
Melnickta
Looks great! I hope mine turns out 1/2 that nice.
Old 05-09-2015, 12:52 PM
Buzz44's Avatar
Buzz44
Buzz44 is offline
Thanks take your time and you will do fine. Prime and sand prime and sand. If any dents before prime either work them out with hammer and dolly or fill with bondo body filler. Holes have to be welded up or filled somehow. I am hearing there is now some sort of miracle filler out there to plug holes and do body work over short of welding them up. Just a few pics of my prep work until I screwed up and grabbed the wrong paint. I was going to go with a black gloss and clear coat for a mirror shine. I guess I could have but got frustrated at my mistake and didn't want to prime and sand anymore..... LOL
Old 05-11-2015, 11:41 AM
Melnickta's Avatar
Melnickta
Here are pics prior to taken prior to unmasking. Had lots of overspray on the exterior that I was able to remove (thank goodness) from my new paint job. Now on to installation of the carpet, seat cover and headliner...
Old 12-28-2021, 08:37 AM
DannyF67's Avatar
DannyF67
DannyF67 is offline
Did you remove original paint or what did you do.
Old 12-28-2021, 09:51 AM
ibuzzard's Avatar
ibuzzard
ibuzzard is online now
Panties NOT in a Twist
Danny, my best advice is to check the date of the thread, as well as the users profile, before replying in a thread. Checking the profile will tell you if the member is even still active here. In this case, the OP has not ben on FTE for over 6 years. Most often it is best to start a new thread. Good luck
The following users liked this post:
Old 12-28-2021, 10:49 AM
624WD's Avatar
624WD
624WD is offline
Hey Buzz,
these are available in the aftermarket by a vendor who makes tilt hoods and the brackets for bucket seats. I’ll search for the link and attach … unless you beat me to it and find it before I do.
Copperstate Components…. step well trim… extremely high quality product
here it is:
https://www.copperstatecomponents.com/store?page=1&perPage=16&q=Step%20well%20trim
Old 12-28-2021, 03:01 PM
EricJ's Avatar
EricJ
EricJ is offline
I was trying to find Duplicolor automotive colors, in the paint shop series and couldn't, I only found a few generic colors. I need to do the interior in my '65 Falcon , #5 Twighlight Tourquois. Any suggestions?
Old 12-28-2021, 04:17 PM
53deere's Avatar
53deere
53deere is offline
If you want an online source you could try this place.... https://everestautomotivemarket.com/...tion_id=957848
SCFlareside
01-10-2018 08:10 AM
vidaliaman
Paint & Bodywork
11-12-2017 07:53 AM
96halfton
03-01-2017 03:22 PM
Devdye
05-26-2016 07:21 AM
harrelle
26
07-03-2013 07:32 PM
Quick Reply: Painting the interior of my cab
