292 Y Block
The Y block is a good engine when maintained correctly. They require clean oil and an occasional valve adjustment. There is a dog leg between the deck and heads where oil can clog the passages if not kept clean, changed on schedule. This results in oil starvation at the rockers. The solid lifters are difficult to change, they're captured.
If I were installing another type engine in place of a flat head, I would probably go with a more modern engine such as a SBF or SOB, something with parts more readily available.
I've owned several Y blocks over the years and they've all been good.
66_in_ky
06-14-2008 05:38 PM
Fordication
06-18-2004 10:12 PM
