Help: truck won't start
Check your starter and check glow plugs for continuity check with dmm or a light. There's you tube videos of how. I had to replace all of my plugs because all the cranking killed the plugs and it was a bad starter. If its slow cranking and if you have like me a electronic fuel pump turn key on hit the Schrader valve on the fuel filter housing. If fuel comes out then that you are getting fuel. Sounds like IP pump is OK as well. But like my post I bet that this is what has happened to the truck. Check them out and see what happens
My starter sounds good. I could be wrong but t'a cranking strong. I do know I have a few glow plug issues and need to rewire them as well. But will the truck still not start in 90degree weather if the GP aren't 100%? I know these trucks are picky but I feel like they would still start in 90 degree heat.
Received 3,117 Likes
on
But if you have a dmm you will know with the continuity test ... Ol means that they are bad and if they maintain .5 ohms give or take they will be good. It only takes a few seconds to disconnect the harness and check each one. Both my starter and plugs despite brand new went bad due to multiple long cranking. Or if you have the light that will tell you as well. You are trying to diag two separate systems at the same time. Due a test on the starter as well. It could be in spec but barely
on
But if he is getting fuel at the injector, more than likely he has power at the fuel shut off. Whats the story? Did it just not start one morning after using it regularly, did it die out on the road? has it been sitting for any length of time, did it act up after fueling it up? more info is needed. Just because you see fuel at the injector doesn't mean you have enough pressure to pop the injector, A common problem is the fuel line, rubber one that feeds the fuel pump has a tendency to crack and suck air, so you get some fuel but not enough for the pump to build pressure. check that.
on
3 wires, the FSS , the high idle solenoid, and the timing advance in the back.
I had a similar problem after I installed a new fuel filter. It started and ran for about five seconds, then died. When I started it again, it cranked for a good 10-15 seconds before it fired.
I won't be of help like some of these guys are, but it sounds like a fuel problem to me. One of the previous posters suggested a fuel line developing a leak. I'd look into that, because if you can't maintain pressure in the fuel system then you're dead in the water.
Roughneck9579
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
02-11-2017 08:30 PM
truckintony
20
03-24-2011 04:04 AM
walnutcreek
04-03-2003 09:13 PM
