door locks
Would be nice to have better pictures of what to do with the foil inside the stator...The text write up is not clear..
forgot the best part as I still have to do the other door, when the stator is out you will see a small flat maybe 1/2'' x1/2'' x1/16'' plate it sits in the plastic piece of the stator take it out and add a small piece of Alumum foil at the bottom to build it up slightly you will see the contacts go just below that stuff it in then add the plate back on top spin the stator and ( note there are two small washers on the stator shaft these go behind the Brushes in the plastic piece ).
Aus56
06-28-2014 06:35 AM
