'57 f100 rearend mounting
on
you can buy new spring perches at most speed shops. you just cut the old ones off and re-weld the new ones on.
the only problem you might run into is that there might not be a lot of clearance between the axle and frame rail and you can bottom out.
what i did was remove every other spring and made longer rear shackles to get the rear end down about 3 or 4".
rgds
Mike
rgds
Mike
rustfarmer
04-07-2007 02:41 PM
kevkel
01-02-2005 08:03 PM
