General Automotive Discussion
Windshield wiper problem
Old 04-24-2015, 10:05 PM
fixnair's Avatar
fixnair
fixnair is offline
i have a '03 wind star van. The wipers don't sweep the drivers side clean. It leaves a triangle patch of glass about 10" on a side right in front of the driver" very annoying.
I've changed arms, blades and checked to see that the motor was mounted securely. I even swapped arms with the other side. Nothing seems to help. I've also checked, as near as I can, to see that the windshield was flat.
Anybody have any experience with this? I know it doesn't rain in Ca much but that spot gets very dirty.
Old 04-25-2015, 06:31 AM
JWA's Avatar
JWA
JWA is offline
Received 1,394 Likes on 1,103 Posts
Posted this in the van's forums a bit ago:
Originally Posted by JWA
Even though this thread is about a Windstar we might be able to help none the less...........
Being in the windshield install biz its possible but not too common the windshield could be the problem here. Whether some SafeLite POS cheap ill-fitting piece or long term wear a low spot can exist that would cause your issues. I've seen it with the lower priced and quality windshields.
Changing the spring-loaded arm along with adding a new good quality blade tends to rectify this sort of issue. Because you've already done that---assuming new parts were used---the only other thing would be the glass itself.
Has this existed since you obtained the van or a recent development?
Old 04-26-2015, 12:30 AM
fixnair's Avatar
fixnair
fixnair is offline
Thanks again JWA. I was thinking about getting one of those aerodynamic add ons to help
Keep the blade against the glass.
Old 04-27-2015, 10:52 AM
JWA's Avatar
JWA
JWA is offline
You can try every quick fix piece of nonsense out there but nothing does the trick like a fresh wiper arm. Whether you get them from the dealer or in the aftermarket that's the best way to cure this problem.
fixnair
21
05-07-2015 06:53 AM
Sleepy_Dave
07-06-2010 07:31 PM
AllFords1022
03-28-2004 12:55 PM
eigenvector
1983 - 2012 Ranger & B-Series
02-26-2004 04:19 AM
GeneStoner
Garage & Workshop
26
12-11-2003 10:38 AM
Quick Reply: Windshield wiper problem
