General Automotive Discussion
Windshield wiper problem
Old Apr 24, 2015 | 10:05 PM
fixnair's Avatar
fixnair
i have a '03 wind star van. The wipers don't sweep the drivers side clean. It leaves a triangle patch of glass about 10" on a side right in front of the driver" very annoying.
I've changed arms, blades and checked to see that the motor was mounted securely. I even swapped arms with the other side. Nothing seems to help. I've also checked, as near as I can, to see that the windshield was flat.
Anybody have any experience with this? I know it doesn't rain in Ca much but that spot gets very dirty.
Old Apr 25, 2015 | 06:31 AM
JWA's Avatar
JWA
Posted this in the van's forums a bit ago:
Originally Posted by JWA
Even though this thread is about a Windstar we might be able to help none the less...........
Being in the windshield install biz its possible but not too common the windshield could be the problem here. Whether some SafeLite POS cheap ill-fitting piece or long term wear a low spot can exist that would cause your issues. I've seen it with the lower priced and quality windshields.
Changing the spring-loaded arm along with adding a new good quality blade tends to rectify this sort of issue. Because you've already done that---assuming new parts were used---the only other thing would be the glass itself.
Has this existed since you obtained the van or a recent development?
Old Apr 26, 2015 | 12:30 AM
fixnair's Avatar
fixnair
Thanks again JWA. I was thinking about getting one of those aerodynamic add ons to help
Keep the blade against the glass.
Old Apr 27, 2015 | 10:52 AM
JWA's Avatar
JWA
You can try every quick fix piece of nonsense out there but nothing does the trick like a fresh wiper arm. Whether you get them from the dealer or in the aftermarket that's the best way to cure this problem.
fixnair
21
May 7, 2015 06:53 AM
Sleepy_Dave
Jul 6, 2010 07:31 PM
AllFords1022
Mar 28, 2004 12:55 PM
eigenvector
1983 - 2012 Ranger & B-Series
Feb 26, 2004 04:19 AM
GeneStoner
Garage & Workshop
26
Dec 11, 2003 10:38 AM
