Battery Light Wont Go Away
I have a 1996 F 250. It has the 7.3 PSD in it. I have had a battery light on for years. I read somewhere it could be the ignition switch going bad. I changed it and the battery light never went out. The truck charges fine and the batteries last for years.
Anybody have a clue as to what it could be?
All that light means is that there is a voltage difference between alternator output and battery voltage. I would measure alt output terminal to case ground and chassis ground as well. Compare this to voltage from battery + to chassis ground and since you have dual batteries do both of them.
Received 3,108 Likes
on
I changed my alternator and my light would come on intermittently had alt check it was good, checked the white plug it was good, stripped back the harness and a po had changed the plug out in the past and connections were good. I re-wrapped the harness and then added a bigger ID and longer piece of convolution to the outside of it and taped it securely, light hasn't come on since. I believe the harness vibrates and causes a intermittent loss of connection. Hope this helps.
