Shaved handles and Electric door poppers?
As far as shaving, no (never trust something electronic that will ultimately keep you from accessing your vehicle....cause it will!) I am currently looking into installing the electric door locks that does come with two remotes. Found one on ebay that looks promising. Would like to see what others have done before I jump into this.
Not to hijack, but did you install them on trucks without factory power locks? If so got any picks of them? Thanks
My truck did not have factory power locks, I just installed the kit with the actuators and key-fobs. All trucks have the mounting location for the factory solenoid though, it's held on by one rivet. I used that same hole, plus I had to drill one more for the solenoid from the kit. The kit does not have a rocker switch on the door for lock and unlock from the inside.
Here's a pic of the factory solenoid and harness, and a pic of the kit that I installed in another vehicle.
pic is sideways...
pic is sideways...
SpencerS
08-28-2017 08:32 AM
ALBUQ F-1
06-18-2014 08:37 AM
