1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Emergency Brake Cable Broke: How Fix?
Old 04-21-2015, 05:51 PM
TomBrooklyn2's Avatar
TomBrooklyn2
TomBrooklyn2 is offline
Trailering
Question Emergency Brake Cable Broke: How Fix?
1999 F-250
How does one replace the emergency brake cable? Are there any tricks or tips to it?
The cable in the '99 F-250 I recently bought broke.
The cable was sticking when I got the truck. I like to use the emergency brake every time I park. The previous owner(s) didn't use the emergency brake and the cable had frozen up.
I tried using it every time I parked. I could tell it was frozen, but I was hoping it would loosen up. It held a little bit when I used it; but soon it just broke.
Old 04-21-2015, 07:21 PM
Jmatthews's Avatar
Jmatthews
Jmatthews is offline
is a BAAAD MAN
Originally Posted by TomBrooklyn2
1999 F-250
Where did it break? Mine broke at the pedal, I had to unbolt the pedal assembly to get it hooked back up but it wasn't too hard. There are several lengths determined by long bed , crew cab etc. I would get one from Ford because o'rellys gave me one that was to short.
Old 04-21-2015, 08:29 PM
92f150I6's Avatar
92f150I6
92f150I6 is offline
depends on which cable broke, mine has 4. Need to remove the pedal assembly to replace the front cable. It is likely that that the rear cables are froze in which case if you broke the front, i would replace them all if the pedal is still stiff.
Old 04-22-2015, 01:51 AM
Psyclopse's Avatar
Psyclopse
Psyclopse is offline
Right- there are 4 cables to the setup- 3 are jacketed and one is bare:
1) jacketed cable from pedal to about the front of the door.
2) bare cable from there to a little before the rear wheel well
3) jacketed cable to the LR brake
4) jacketed cable to the RR brake
The bare cable needs to match your configuration, such as single cab, extended short, extended long, crew short, crew long or Excursion. This seems to be the one that most often breaks, and if it is broken, TEST THE OTHERS for smooth operation through their jackets as well.
WindBlue72
05-08-2019 11:55 AM
UP_There
08-02-2016 09:04 AM
Dave S
08-19-2008 04:18 PM
400944
04-20-2008 01:44 PM
snakebit
05-01-2007 05:02 PM
Quick Reply: Emergency Brake Cable Broke: How Fix?
