1993 idi oil change questions
Old 04-21-2015, 04:35 PM
Ryan Weaver's Avatar
Ryan Weaver
Ryan Weaver is offline
Oil always stays black that normal? just put brand new oil and its black first start. what do you change the oil at what interval
Old 04-21-2015, 08:17 PM
Chevy_Eater's Avatar
Chevy_Eater
Chevy_Eater is offline
Yep, it's normal, diesels show contamination in the oil after the first start.
Interval is a matter of opinion/choice, but anything under 5K is overkill.
Old 04-21-2015, 08:54 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
Old 04-21-2015, 09:57 PM
Xyeniko's Avatar
Xyeniko
Xyeniko is offline
What i normally do for oil changes on any old diesel engine is; Get it up to normal operating temperature, shut it down, add a quart of diesel fuel to the oil, then run for 5 minutes, shut down and drain overnight from pan and filter. gets it to stay cleaner after the first run. Works for dump trucks tractors etc. Just an idea if you want a "cleaner" looking oil, but otherwise i really wouldn't worry.
Old 04-22-2015, 10:49 PM
speedwrench72's Avatar
speedwrench72
speedwrench72 is offline
ya goes dark pretty quickly I use moble 1- 601 filter (its a power stroke filter) it employs a duel stage filtration, and is larger than a Idi filter, fits most aplications (11 quarts) oil.
Old 04-22-2015, 10:58 PM
FORDF250HDXLT
much larger than a oem psd filter too.
Old 04-23-2015, 07:26 AM
hs108's Avatar
hs108
hs108 is offline
Ya, black oil is just part of the game.
I too run the M1-601 filters, I found them on sale at amazon for 7 bucks a pop, and I only bought 2? What was I thinking????!!!
Old 04-23-2015, 10:26 AM
FORDF250HDXLT
i was silly as well.i only grabbed 4 during that $7 each time period and iv got 2 trucks......darn i should have grabbed a dozen.
Fefanatic
1999 to 2016 Super Duty
02-05-2018 03:12 PM
fmuguira
2017+ Super Duty
09-01-2017 08:06 AM
Polkster
06-11-2017 10:43 PM
99StrokeXLT
01-23-2011 07:12 PM
priv8pilot
11-18-2006 10:00 AM
Quick Reply: 1993 idi oil change questions
