EGT temps
That's not a bad idea. How much do you think an upgrade like that would cost, assuming I do the work myself?
Riffraff sells the high flow outlet for about $85. It will eliminate the EBPV.
I did this to my Excursion when I first bought it. Along with Clay's turbo rebuild kit, the wicked wheel & new pedestal O-rings.
The intercoolers vary in price greatly.
The 6.0L IC's can be found for a few hundred and from what I have read will drop the EGT's a good 100 degrees when towing.
I went with the DI Intercooler (Diesel Innovations) and that runs about $1200. Put one in the F-250 in 2006, it dropped my EGT's by 200 degrees when towing and drops the Manifolt Air Temps to 10 degrees above ambient - sweet!.
The SPearco/turbonetics does great as well 200+ degree drop - $1700 to the wallet........Yes, these last two are a big pill to swallow. But I haven't regretted buying the DI one bit.
Sent you a PM with my # if you want to chat about it.
You can control the wallet bleeding by only doing one at a time. The high flow outlet is the least expensive but requires you to take the turbo out.
Garrett GTP38 High Flow Outlet - Riffraff Diesel Performance
http://www.dieselorings.com/garrett-...st-outlet.html
The 6.0 intercooler is the least expensive of the 3 intercoolers and still yields a 100 degree temp drop.
I wouldnt call it easy, but i wouldnt call it all that difficult either. It looks more intimidating than it actually is. I pulled mine and rebuilt it last summer and reinstalled. There were times that getting my fat @$$ in position was a bit tricky, but if i can do it, im sure most others can as well. There are lots of threads detailing steps to remove with pics as well as numerous youtube videos. Just do your homework beforehand and dive in......
on
Exactly! Get some pillows or cushions. Once you are comfortable, its relative, then the rest isn't bad.
Link to instructions to save you a bit of time:
http://www.riffraffdiesel.com/conten...structions.pdf
