Easiest Firewall Opening For Wires?
I installed a ham radio setup today in my 2010. On the passenger side on the firewall there are 3 big electrical plugs a little below them is a small rubber plug that is where I ran my wires and coax. I pulled the plug cut a hole in the insulation and fed the wires through it is very tight because of the fan motor and duct work. I pushed a lot of coax through and then used a 24" claw tool and a flashlight grabbed the coax and pulled it through and did the same with the power wires.
Driver side, to the right and above the steering column. Kinda between the brake and gas pedals. There's a heat shield on the interior, but you should be able to see it from the hood side.
I've got a ~3" diameter bundle running through there. I do run the entire thing in heavy split loom to protect it.
jlag
1999 to 2016 Super Duty
13
10-15-2008 11:27 PM
javi2001
16
12-31-2007 08:30 AM
grelsner96
09-06-2007 08:25 AM
