bronco quit running
bronco quit running
Hey,
So I'm a mechanical noobie. Have a 88 bronco with 110k miles.
Yesterday I started my truck to warm it up, started right up. After about 10 min it died. tried to start it, it just continually revs. Thought maybe it was out of gas, Put more in, but had no progress. Not sure where to go from here. Had read possible fuel pump issues. Had been idling rough recently as well. Any info would help.
Thanks
Thanks
Well first, run the codes and see if anything pops up. You can do it with a code reader that you can buy for $20 to $30 at an auto parts store, or on amazon. Or you can do it with a paper clip. (Ive never done the paperclip method before, but others on here have) Check your fuel pressure if you can. Let it idle and watch the gauge, especially while its reving (if it does) For a 351 the pressure should be just above 30psi I believe. Im not sure for a 5.0 but it should be around the same. If the fuel pressure is low, or if you feel like digging around, check the fuel pressure regulator, which looks like a vacuum canister on the top back towards the driver side firewall. It should be held on by three allon head screws that are a pain to get to. Also you might want to check the voltage getting to the high pressure pump. Thats about all I can think of for the fuel system. Make sure to check your codes to see if any sensors are out of whack.
