Dome Light
The lamp/socket base has a wire that screws to the back of the cab. The lens and socket base are floating on the head-liner (on mine anyway) and so you have one short wire to the switch with a male plug and the other short wire has a ring terminal you use a screw with. The truck body as all ground.
Or Earth if you are in the UK...
The single wire sounds to me like the C7TZ-13786-A housing rather than the C4TZ-13786-A housing with two wires.
Check out this eBay auction - on the one you bought see if the black wire has a Ford number on it and let us know what it reads if there is any there.
http://www.ebay.com/itm/NOS-67-68-69-70-71-72-Ford-F100-F250-F350-Dome-Light-Housing-C7TZ-13786-A-/191543634063?hash=item2c98e3e88f&vxp=mtr
learpilot
10-03-2009 08:26 PM
ZombieSlayer
04-09-2004 10:37 AM
