Courtesy Lamp
My socket did not have one in it.
1961/67 F100/750: Dome light #1003 / 1968/69 #1004 / 1970/72 #105
1965/68 Mustang: Courtesy Light-under dash #631 / Courtesy Light-door mounted #90 or #1004 / Courtesy Light-console mounted #1816
1967/68 Mustang Dome Light #1003
The #105 bulb and the #1003 bulb are similar in that they both are single contact and have the same brightness (candlepower rating) but the size of the glass part of the bulb is different.
The #1004 bulb is a two contact, single filament bulb (obviously requiring two wires, a ground wire and a positive wire).
The 61-67 and the 70-72 housings ground against the cab body. Why would the 68/69 housing require two wires?
I'm just the messenger...I read the catalog, and type what I see.
1964/72 Ford Truck Parts Catalog / Section 134 / Page 11 / Miniature Bulb Chart / F Series.
Verbatum
1961/67: B6AZ-13466-A .. #1003 Bulb / Single Contact - 15 Candle Power
1968/69: C3SZ-13466-A .. #1004 Bulb / Double Contact - 15 candle Power
1970/72: D0AZ-13466-A .. #105 Bulb / Single Contact - 12 Candle Power
Body & Socket-Dome Lamp
1961/66: C4TZ-13786-A
1967/72: C7TZ-13786-A
The question is: Which bulbs are correct for 1968/72?
A double contact bulb won't work with a single contact socket.
It's obvious to me from what I typed, that the #1004 double contact bulb listed for 1968/69 is in-correct.
