Pop noise now grinding
Old 04-10-2015, 08:40 PM
Hitagain's Avatar
Hitagain
Hitagain is offline
Driving at hwy speeds and head a pop noise in front end. Stopped and couldn't find anything, heard it a couple of more times, still nothing found, now I have a grinding noise left front wheel. Im out of town in bowling green, Ky. and need ideas of what the issue may be. 2001 Ford EX 4X4.
Old 04-10-2015, 08:43 PM
LivingLarge's Avatar
LivingLarge
LivingLarge is offline
Possible front hub assembly (wheel bearing)
Old 04-10-2015, 08:46 PM
Hitagain's Avatar
Hitagain
Hitagain is offline
Also, if anyone knows any good repair shops open tomorrow in Bowling Green, Ky. That would be great.
Old 04-10-2015, 10:39 PM
Krazee Matt's Avatar
Krazee Matt
Krazee Matt is offline
x2, the symptoms and sounds described are exactly what happened when my left front hub assembly finally failed and seized on me on the freeway. End results were less than desireable and ended with an unintentional exit from the freeway with 5500lbs in tow.
Not to worry you or anything....
Old 04-11-2015, 07:44 AM
Hitagain's Avatar
Hitagain
Hitagain is offline
Does anyone know off hand if the hub if fine or course thread?
Old 04-11-2015, 08:39 AM
JuanHuevos's Avatar
JuanHuevos
JuanHuevos is offline
I'm still around...mostly
2001 was coarse thread.
Old 04-11-2015, 05:07 PM
Hitagain's Avatar
Hitagain
Hitagain is offline
Hub was the issue, replacing the hub also fixed a brake issue, I needed to fix
resq302
08-21-2018 10:29 AM
RolnCl
09-08-2015 08:48 AM
ANigrelli132
06-24-2014 10:38 AM
meier63
22
01-30-2012 02:32 PM
Rat wagon
04-14-2003 08:03 AM
Quick Reply: Pop noise now grinding
