Clicking hubs,how do I shut'em up??
I got a 1970 250 4x4, or a 1972+ 250 4x4 I can't be sure. The drivers side hub makes a ratchett noise while I'm driving. 4 wheel works and everything but that noise annoys me! What causes it, and how do I fix the noise??
great big thanks to those who got some info
Many times the reason it clicks is the hub was not put back correctly when it was removed. Usually the spring or cam is not seated correctly.
Totally remove everything down to the clip on the axle, hub, or wheel bearing (not sure what the 250 looks like for that year and if it has a 44 or Dana 60) and reinstall everything.
Usually if it is not installed correctly and it is clicking, the arrows do not like up to where it reads "lock" and "unlock" and you do not get a positive click feel/sound when you unlock the hub (unless it is a Mile Marker, they click when they go in).
