Spare tire question
Spare tire question
When I bought my 08' F-350 there was no spare and nothing behind the seat. I need to replace it all. I have a line on a few spare wheel tire combos in my area but the tires aren't the exact same size as the tires that are currently on my truck. Will this be a problem ? Also what items do you see behind your seat ? Also besides the spare under the back, what else is there. I currently have nothing
Thank you
Matt
Thank you
Matt
My first inclination would be to look on Ebay for the hardware- jack and handles- or on www.car-parts.com, which will get you information from salvage yards. You also need the special key for the tire winch- mine was inside a pouch in the glove box. Do you still have the tire winch installed under the truck? You need that, too.
A spare that is odd sized can work, or be a problem- that depends on your conditions. If you are going to limp to a shop to get the tire fixed, it will work. If you want to put the spare on and drive 500 miles before fixing the tire, I would hesitate- I'm not a fan of mix-matched tires on a drive axle for any distance, and I don't think I would like the driving characteristics on the front for any distance. It will work in a pinch, but obviously a spare that is matched to your other tires is the best option.
The special key is not a big deal. There is a thread decribing how to pop out the insert so you can just use the jack handle/crank. I agree that matching tire size would be best, but it's only the circumference that matters. If that is the same it won't matter what size wheel the tire is on.
Sous
20
01-26-2018 09:57 AM
awq134
2009 - 2014 F150
03-11-2013 06:02 PM
