2nd try widening rear fenders
Here's my second attempt, tried making my cut as close to mounting flange as possible. There's still a Lot of taper in these fenders. It's better than the first one, but not as good as I would like. I have another set of rears, any new ideas?? Besides buying fiberglass...
Received 4,200 Likes
on
Without access to the hammers and english wheel to help form the compounding curve especially where the horizontal meets the vertical is very time consuming. Has to be done by hand forming. The vertical pc is a little to far into the curve ( the corner). You can see right where the pc you added starts going away from the original fender, cut the new pc right there and than form a pc a little wider there to the compounding curves. Fit, trim and form, fit trim and form etc until you have it to your like. Weld Polish than filler and shape the filler than finish. My inner wheel well widening, very similar to your project but not as big, took me about 30 hrs per side and I am light on that figure.
That was my intent for benefit of others that are playing along at home Gonna take some time so has to wait until Fri. Got a date tomorrow with a girl I used to date in HS 50 years ago! Just caught up with each other a few months back. First first date in ~ 35 years, hope I still remember how.
