ABS Control Module
ABS Control Module
Hi everyone, I have a 1992 F150 4.9 E40D 2WD and I was behind the glove box the other day and noticed my ABS Control Module was unplugged so I plugged it back in and the rear abs light came on. So I unplugged it again, does anyone know if I would need to re program something to have the light shutoff? I had the heater core replaced over a year ago and I think my dads friend forgot to plug it back in when he put it back together. Thanks everyone
-Cory
-Cory
No reprogramming necessary. If the light is on then get the fault code and go from there.
Mine was unplugged when I bought my truck. Plugged it in and the light came on during the power up test and then went out like it should. But as I started driving it the speedometer started bouncing and the auto trans went to failsafe mode... I checked it out and came to find out that the ABS controller was screwing with the speed signal, so I took it out, cracked it open, couldn't find anything wrong so I tossed it in the trash. Got a module from the junkyard, same problem. Tossed that in the trash too. I don't need no stinkin' anti-skid brakes...
7.5GasHog
32
03-05-2018 03:45 PM
85F350IDI
03-03-2016 04:27 PM
