ABS Control Module
Old Apr 5, 2015 | 04:06 PM
f15olandscape's Avatar
f15olandscape
ABS Control Module
Hi everyone, I have a 1992 F150 4.9 E40D 2WD and I was behind the glove box the other day and noticed my ABS Control Module was unplugged so I plugged it back in and the rear abs light came on. So I unplugged it again, does anyone know if I would need to re program something to have the light shutoff? I had the heater core replaced over a year ago and I think my dads friend forgot to plug it back in when he put it back together. Thanks everyone
-Cory
Old Apr 6, 2015 | 03:17 PM
dixie460's Avatar
dixie460
No reprogramming necessary. If the light is on then get the fault code and go from there.
Mine was unplugged when I bought my truck. Plugged it in and the light came on during the power up test and then went out like it should. But as I started driving it the speedometer started bouncing and the auto trans went to failsafe mode... I checked it out and came to find out that the ABS controller was screwing with the speed signal, so I took it out, cracked it open, couldn't find anything wrong so I tossed it in the trash. Got a module from the junkyard, same problem. Tossed that in the trash too. I don't need no stinkin' anti-skid brakes...
Old Apr 6, 2015 | 08:20 PM
f15olandscape
Dixie460 thank you I guess I'll have to scan it and see what's wrong I've already replaced the control module that's on the frame that the brake lines run into so this module must be the problem
Old Apr 6, 2015 | 10:32 PM
jimistephen's Avatar
jimistephen
In my opinion the RWAL that Ford had is just useless. I've never liked it and always unhook it.
wiredgeorge
May 19, 2019 06:47 PM
7.5GasHog
32
Mar 5, 2018 03:45 PM
85F350IDI
Mar 3, 2016 04:27 PM
clipnclop
1997 - 2003 F150
Jul 9, 2007 08:45 PM
