A/C clutch
A/C clutch
Pre-thinking my Bronco Wiring, and I think I have a good grasp on how I am going to wire in the engine harness to the under-hood harness, and using a few pre-existing wires to run the WTS light and such. However, I am retaining A/C on this build, and I want it to function properly. Did the IDI's cut A/C at WOT like the EFI gassers did? I don't see any way it could feedback unless you have an E4OD truck...
Anybody have a wiring schematic for the A/C clutch?
I don't see any Grey/White wire on any of the near by years be it truck or bronco. Being a heat shrunk area on the wire insead of a solid rubber block with either "Diode" or the electrical symbol of a diode written on it, I'm guessing someone added it in. I'm thinking it mite be the should be black/yellow but is now Grey/White that goes to the EEC. Can you ohm it out to see what it may be connected too? If it is connected to the black/yellow that goes to the clutch, just ignore it or chop it off.
The G/W wire wasn't added, this thing was pristine stock. The odd part about it is I have come across more than one on the chassis side... I am going to leave it unhooked, and figure it out if the A/C doesn't work... It is possibly that was the circuit that went to the EEC on the diagram, and if that's the case, no issue, Ill pull the wire out of the plug.
bigcrunch
02-13-2018 10:59 PM
66crawler
09-15-2012 10:12 PM
81Ford_Stepside
10-16-2008 10:27 PM
