Front axle question
Front axle question
The PO put a different front axle in my 48 F1 that is roughly 3" to long causing the springs to not sit properly on the axle. My questions is would a used axle (if i can find one) be ok, or just I just spend the money to buy a brand new ?
I currently have a 351 Windsor, auto tranny, disk front brakes, 15" wheels, planning to make a daily driver on the streets with light hauling. Nice looking but no show truck.
I don't think you will have any trouble finding a used one hopefully close to you. Many guys have chosen to go with a Mustang 2 fronts, which leaves an unneeded stock axle sitting around in the shed or garage. If you do go with a used one I would replace or at least check the wear on the king pins. It would also be a good time to check tie rods, drag link etc. Best of luck.
Christopher2
02-23-2005 08:25 PM
reamer
02-02-2005 03:30 PM
